Maximum Device Burst Rate
Note: This preference is only available for DI-149, DI-155, and DI-2108 products.
The Maximum Device Burst Rate preference allows you to tweak the burst rate when superfluous gaps occur in your data (using a DI-149, DI-155, or DI-2108). Some computers may not be able to handle acquisition at high speeds and require you to lower the burst rate.
To set the maximum USB Burst Rate:
In the Preferences sub-menu click on Maximum Device Burst Rate
Choose Edit Preferences Maximum Device Burst Rate (ALT, E, P, U).
When Maximum Device Burst Rate is selected, a dialog box allowing you the enter a burst rate value displays.
Enter a value in the Maximum Device Burst Rate text box and click OK. Finding the most ideal burst rate is a matter of trial and error. Once an optimized burst rate is selected use the File > Save Default Setup command to save the value.
